Calculate BTU output of my old cast iron radiators
Amy FitzGerald
Member Posts: 5
Can someone recommend a website that is user friendly that I can use to calculate the BTU output of my old cast iron COLUMN TYPE radiator as well as the TUBE TYPE models?
E.D.R. Book
Dan, this website's creator, compiled a book that will help you.. http://www.heatinghelp.com/products/Books/5/80/E-D-R-Ratings-for-Every-Darn-Radiator-and-convector-youll-probably-ever-see
I used it recently and found it very helpful.1-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics0 -
Dan's book
will give you the effective radiating area, called EDR, of the radiator. Then multiply by 240 to get the output in BTU for steam.Br. Jamie, osb
