Just bouncing an idea around..
Werewolfx
Member Posts: 16
Anyone have any thoughts about building a house today, utilizing a steam system for primary heat? I've searched a little, but not come up with anyone building a house and installing a steam heat system. Is there a good reason for this? I've come to like steam systems, and it appears a lot of others do as well, but aside from the complications of installation compared to forced air, is there a real reason not to?
If
I were to build a new house today (which, God forbid!) it would be mostly passive solar -- but the boost would probably be steam (up here in the north country -- further south it would be a heat pump). Why don't people? My guess would be unfamiliarity with steam on all parts -- home owners, architects, and trades people -- and money. I don't think one could build a new steam system for less than a scorched air system; in fact it might be a good bit more. Might be competitive with hydronic, though.Br. Jamie, osb
Cost
Let's face it. Builders are going to build new homes for people the fastest and easiest way they know how. Soldering copper pipes, PEX, baseboard, is way easier than cutting, joining, pitching and adjusting steam systems. So is everything involved with a forced air system.0 -
Component Cost and Flexibility
Have you tried pricing brand new radiators these days? A medium-sized one might cost you $1000. So price out a boiler, a half a dozen radiators, valves, vents, controls, and installation . . . and I think you could easily double or triple the cost of a forced air system . . . and then, if you wanted central air, you'd need to start over and install a complete second system.
I'm having fun tinkering with my steam system, and it has a certain "retro-coolness" factor, and I do enjoy the even heat . . .but despite the drawbacks, If I could afford to do it, I'd trade it for a modern high-efficiency forced air system in a heartbeat.0
- 109 Chimneys & Flues
- 975 Plumbing
- 386 Solar
- 17 Recall Announcements
