Whats wrong with this picture?
cwilliams2000
Member Posts: 140
Hi everyone, I am buying this house and at first the heating system seemed pretty good, peerless boiler, etc. But the more I look at this, it makes me wonder. #1 they seem to be running the separate water zone off the hot water coil, I would think this is a mistake. #2 the way they did the valves looks like a lot of trouble, but then I realize that the zone valve are actually up high by the ceiling above the heating system. Can you give me any suggestions, am I being too picky? Plus of course, I am getting a nice swing door boiler, but then I look and realize there is no quick disconnect on the burner for power, so my guess is that the door has never been opened.
What would you do here, or any tips? thank you
I think,,,,
The install looks quite professional.
You`ll look at 100 jobs, and 100 will be different,,,, looks OK to me. :-)0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
