Pennco 1605HSD pilot won't stay lit
reedvalve
reedvalve Member Posts: 1
Hey-
I just found this great forum after searching around google for some gas fired steam boiler info.
Following the lighting instructions on the side of the unit, I tried a few times to get the pilot lit (it went out a few hrs ago).  At first it wouldn't stay lit after letting go of the red button.  Once it did stay lit for a minute but then went out. The last time it stayed lit and I got the boiler to fire, but it went out a minute later.
I'm going to call for service tomorrow but I'd like to know what the problem might be so that I don't get ripped off (hopefully the company & tech will be honest). I've been meaning to do the right thing and have a pre-winter check done anyway.  Fortunately its not freezing yet.
Thanks in advance
-Ethan
  • Tim McElwain
    Tim McElwain Member Posts: 4,657
    Probably needs a new
    thermocouple and the pilot will need cleaned. Check Hot Tech Topics "Procedures for Troubleshooting Thermocouples" so you do not get ripped off. A good tech will follow those procedures and take some millivolt readings.
