Boiler electrical protection
kcopp
Member Posts: 4,630
I have a Embassy Onex boiler that has had 2 control boards "break" in the last month. Mfg. feels that the power to the home is suspect.... Recommends that a "surge suppressor" or power conditioner be added to the circuit. Anyone run in to this before w/ a boiler or furnace? What did you use? A $10 one at Lowes probably won't do it... ty.kpc
I had
to use one on a Viessmann Vitodens that was acting up about 3 years ago. Ended up buying a Panamax M4T-EX Power Conditioner and haven't heard a peep from the owner since.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab0
