Boiler electrical protection
kcopp
Member Posts: 4,436
I have a Embassy Onex boiler that has had 2 control boards "break" in the last month. Mfg. feels that the power to the home is suspect.... Recommends that a "surge suppressor" or power conditioner be added to the circuit. Anyone run in to this before w/ a boiler or furnace? What did you use? A $10 one at Lowes probably won't do it... ty.kpc
I had
to use one on a Viessmann Vitodens that was acting up about 3 years ago. Ended up buying a Panamax M4T-EX Power Conditioner and haven't heard a peep from the owner since.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
