Spirovent trouble
Jeremy
Member Posts: 52
Hello Wallies-Anyone have any problems with a spirovent not eliminating air from a system? We put in a new boiler in June and seems I still cant get all the air purged from the system. After power purging, its ok for a few days but thats it. Job is piped pumping away with 3 zone valves, (2 zones cfbb, 1 zone indirect), #30 expansion tank, 329 water feeder (piped under spirovent), Spirovent is 1". I posted pics of this job on the wall but cant seem to find them. . Thanks.
Jeremy
Jeremy
Dawn it...
Add one ounce of Dawn liquid detergent, and say good bye to Mr. Bubble.
Seriously.
ME0 -
how?
does that work?There was an error rendering this rich post.
It acts as a surfactant...
releasing bubble tension, and causing the bubble to be easier trapped by the aglomulator in the micro bubble resorber.
I've used it half a dozen times, including my own personal system, and have not a peep out of it since.
ME0 -
Dawn, eh?
Hey Mark,
Interesting tip I may have to pull out one day.
Where do you recommend adding it? Pop the top of the spirovent and a few drops there or?
Thanks,
Scott KThere was an error rendering this rich post.
I carry a small Silver King force hand pump and a bucket...
I drain a gallon or two out of the boiler, squirt in the detergent, mix it up and pump it back in. In a pinch, I've drained the pressure off the boiler, and pulled a relief valve and poured it in there. Whatever is the easiest for you.
It beneficially raises the pH of the boiler fluid and is antibacterial.
ME0 -
PSI?
Whats the system pressure (cold) and height from boiler to top radiation?
Could be under pressurized0 -
Dirt
Or flux could be trapped in spirovent head. I usually put a cap on the spiro when starting up new system and flush/ refill and then put spiro into action. Do you ever hear the vent releasing air?0 -
How would "Dawn" help?
once you get rid-of the bubbles,, how do you get rid-of the Dawn?
Sounds like a good system flush,,, why not just use Rhomar and be done with-it?
Use-to use dishwashing detergent for tire-to-rim seals,,, do they still?0 -
Pumping away......
Power purging ......... By chance , do any pipes go into a slab ? Sounds like a heating pipe leak if the system keeps going airbound .0 -
I think Kev is on the right
track here. Two zone cfbb, pumping away should clean up real quick. Check your spirovent.0
- 120 Geothermal
