zome vs Grunfos Alpha
mcycle
mcycle Member Posts: 7
<span style="font-size:12pt">I'm about to install a 95% condensing boiler to an existing baseboard system; 3 zones 2000 sq ft home,  135 ft of baseboard element.  One of the zones is an “old school” 1” venture loop. Boiler is a Triangle Prestige.</span>
<span style="font-size:12pt">My original plan was to use the Grundos Alpha circ and pipe using zone valves.  I’ve been getting poor feedback regarding the Alpha, so I’m re considering either a single speed Taco "00" series or possibly 3 circs “one per zone”.</span>
<span style="font-size:12pt">What would be the best option for this type of system?</span>
<span style="font-size:12pt">thanks,</span>
  • adambuild
    adambuild Member Posts: 422
    What poor feedback are you getting re the Grundfos Alpha? I'm asking as I'm about to replace my old beast with a Prestige and zone valves and was planning on using the Alpha!?
    Thanks, Adam
  • bob eck
    bob eck Member Posts: 930
    Grundfos Alpha
    I just installed a Triangle Tube Prestige Excellence in my house with 2" black mains and large radiators.
    I installed a Grundfos Alpha pump and it works fine.
    What kind of problems have you heard on the Alpha pump?
    Good heating with the Triangle Tube boiler.
  • mcycle
    Zone vs Grundfos Alpha
    I had three plumbers say to avoid the Alpha. When asked they did not explain why.
    I was hoping to get an answer from this site.
  • Paul Pollets
    Paul Pollets Member Posts: 3,671
    Alpha advice
    If the plumber's haven't used them, how could they comment? I'll bet the comment was "it costs more"....
     I have used the pumps and they work great!!  Highly recommended when using zone valves.  The Alpha is a very important milestone in pump design.
    hot_rod Member Posts: 26,619
    care to name those 3
    plumbers? Or have them stop buy to explain their advise. I have 3 of the first Alpha version and 3 of the newest version they all work great, better than expected.
    hr
  • JFear
    JFear Member Posts: 3
    No problems here...
    I also haven't run into any problems with the Alpha. We have had a number of contractors install them in various applications with no issues...
