Steam for a garage workshop?
Jason_44
Jason_44 Member Posts: 60
I have one-pipe steam in the house and am trying to figure out how to heat a 1-car attached garage that I use as a workshop.
I've heard that Modine makes garage heaters that work with steam, but the ones I've found are rated for 2 PSI. My pressuretrol is set for 1/2 PSI. Would the Modine still work? Also, would the whole thing have to be piped with black steel pipe? Or is there a flexible piping option?
Here's the unit to which I'm referring...
<a href="http://www.ultimategarageheater.com/hot-water-garage-heater/index.php">http://www.ultimategarageheater.com/hot-water-garage-heater/index.php</a>
Thanks.
Jason
  • Steam or Hot Water
    The answer to your question is "maybe".  While steam heating is quite simple you have to understand the necessary design requirements to make a steam heating system work satisfactorily. It's a little more than just hooking up some pipes. There also maybe an option of hooking up a hot water radiator from your steam boiler. This might be simpiler than trying to run steam.
    What you're going to have to do is either get a steam pro to make the installation for you or learn about steam yourself. For a pro you can look in the "Find a Professional " link at the top of the page or if you want consider doing it yourself, go to the top of the page and in the "Shop" section, get a book called "The Lost Art of Steam Heating" by Dan Holohan.
    - Rod
  • Jason_44
    Actually...
    I have the book.
    What I need is advice specific to the Modine. As I said, my Pressuretrol is set for 1/2 PSIG. What I need to know is whether the Modine will work with less than 2 PSIG.
    Jason
  • Sure,,,,
    2 PSI is the standard rating.
    Piping-it-up  properly to a steam system is the trick! :-)
