WHAT DO YOU THINK OF THESE....
BXNYC
BXNYC Member Posts: 10
two setup.  My dad and I did these two this weekend.  So I need feedback, please.  I'm a bit worried about the one with the horizontal union, any chance of hammering?
Thanks.
  • Daniel_3
    Daniel_3 Member Posts: 543
    UNIONS
    1. You didn't need unions.
    2. Why are there plugs on third pic?
    3. End of the main will be frowned upon  . .slightly . . . but you have good height. Is that pipe leaking in the first pic? Why no venting?
    4. Looks like pic #2 is only 1" pipe and pic #3 is maybe 1 1/4"?
    Are you in the middle of finishing the project? Just curious.
  • But what about water hammering, can it happen?
    Hey Daniel,
      Thanks for the input.
    "1. You didn't need unions."
    -We used unions based on how I kept reading about how good/easy it is for future maintenance/upgrade.
    "2. Why are there plugs on third pic?"
    -Yes those are plugs.  Had to put them in until I got the two air valves, which I now have.  I have included a later pic with the vents on.
    "3. End of the main will be frowned upon  . .slightly . . . but you have good height. Is that pipe leaking in the first pic? Why no venting? "
    -The first pic is a before (top view pic) of the 2nd pic.  No leak, just the wd-40 we sprayed.
    "4. Looks like pic #2 is only 1" pipe and pic #3 is maybe 1 1/4"?"
      -Damn, good eyes.  we were supposed to do only one vent, so I picked up supplies for one and my dad picked for the other.  I didn't want to go back, too much traffic.
    "Are you in the middle of finishing the project? Just curious. "
     Completed now.
    Thanks again.
  • Nice Job!
    I'm a "union man" myself.  I'd pay for a union anytime I can save bashing my fingers.
    Water hammer -  I think you'll be okay. A lot of this is just trial and error. If it works - good! If it doesn't - then you have to think up a "fix"   The Gorton vents have floats so they are expecting a little water sometimes anyway.
    - Rod
  • Daniel_3
    No hammer
    As Rod said it should be fine and you shouldn't experience hammer. Yes, forgive my ignorance in simplicity as unions would certainly make for a quicker change-out in the future . . .good work o'er all.
