B&G or Taco Flow Check Valves - either better?
Pretty simple question:   Is there any reliability or functional advantage between the Bell & Gossett and Taco flow check valves?  Or are they both practically the same?
I see that they are similar in design, although the B&G has an extension of the weighted plug that guides the plug to the seat to in theory avoid chattering and make a more positive seat.
Thanks,
Al
  • I have...
    I have bitched and moaned to the B&G so called engineers at the shows about their too short stem on the flo control to put a wrench on the packing without removing and losing the clip from handle. Why you need to tighten the nut? Because the packing is dry and not greased, therefore, leaks and looks like crap after a year being in service.
  • Al Roethlisberger
    Al Roethlisberger Member Posts: 189
    Thanks
    Interesting observation, thanks.
    I have one of the Taco units and it almost appears that their flat bottomed weighted plug could sit/drop askew on the seat and leak, although perhaps in practice the hydrodynamics won't allow this to occur.
    Al
