need math help!
gerry gill
gerry gill Member Posts: 3,084
Hi Everyone-- i have a math question that my public schooling doesn't help me with..hehe.. when figuring the head loss of a hydronic pipe the formula is r(f)1.75 , with the 1.75 as i think its called an exponent in the upper right hand corner position..siggys example uses .29609 x 5 gpm with that 1.75 thing equals 4.95 feet of head..what keys do i use on a scientific calculator to do this? thats my question..thanks.
gwgillplumbingandheating.com
  • siggy
    siggy Member Posts: 79
    math help
    Gerry,
    Raising a number to a power using a scientific calculator is as easy as multiplication - only it uses a different key.
    Say you want to raise 2 to the 1.75 power.
    Enter 2 on the display, press the key that has a Y with a little x next to it - just to the upper right .
    Then enter 1.75 on the display and press the = sign.
    The correct answer for 2 raised to the 1.75 power is about 3.36359.
    Some calculators operated a bit differently, but any scientific calculator, even one you buy in Staples for 10 buck, has the ability to do this.
    Hope this helps
    siggy
  • CC.Rob
    CC.Rob Member Posts: 130
    windows calculator
    In the standard Windows calculator, try this:
    Go to 'View' and select "Scientific'.
    Following Siggy's example,
    type the number 2.
    now hit the x^y button (between the sin and log buttons)
    type the number 1.75.
    now hit the = button.
    answer is 3.36359
  • gerry gill
    Thanks Siggy!
    I'm reading your Modern Hydronics Heating textbook trying to get a better handle on pump sizing..or i should say better pump sizing..better than the ''well this pump worked well last time method'' hehe..thanks for the quick answer..Great book by the way!
  • gerry gill
    Thanks CC
    I was wondering where to find one of those calculators..math has always put the wipping on me..
