need math help!
gerry gill
Member Posts: 3,084
Hi Everyone-- i have a math question that my public schooling doesn't help me with..hehe.. when figuring the head loss of a hydronic pipe the formula is r(f)1.75 , with the 1.75 as i think its called an exponent in the upper right hand corner position..siggys example uses .29609 x 5 gpm with that 1.75 thing equals 4.95 feet of head..what keys do i use on a scientific calculator to do this? thats my question..thanks.
gwgillplumbingandheating.com
math help
Gerry,
Raising a number to a power using a scientific calculator is as easy as multiplication - only it uses a different key.
Say you want to raise 2 to the 1.75 power.
Enter 2 on the display, press the key that has a Y with a little x next to it - just to the upper right .
Then enter 1.75 on the display and press the = sign.
The correct answer for 2 raised to the 1.75 power is about 3.36359.
Some calculators operated a bit differently, but any scientific calculator, even one you buy in Staples for 10 buck, has the ability to do this.
Hope this helps
siggy0 -
windows calculator
In the standard Windows calculator, try this:
Go to 'View' and select "Scientific'.
Following Siggy's example,
type the number 2.
now hit the x^y button (between the sin and log buttons)
type the number 1.75.
now hit the = button.
answer is 3.363590 -
Thanks Siggy!
I'm reading your Modern Hydronics Heating textbook trying to get a better handle on pump sizing..or i should say better pump sizing..better than the ''well this pump worked well last time method'' hehe..thanks for the quick answer..Great book by the way!gwgillplumbingandheating.com
Thanks CC
I was wondering where to find one of those calculators..math has always put the wipping on me..gwgillplumbingandheating.com
- 50 Industry Classes
