Steam heater
Freefalling
Member Posts: 2
Today when I turned on the heat my steam boiler did something weird. Downstairs in the basement steam was blowing out of one of my pipes. The pipe is coming out of the top of the furnace and it goes 3/4 ways to the ground were it is cut off. Now I noticed when i flip the switch up top it lets steam out of this pipe. Also it says max PSI is 15. when I restarted it and waited once it got to 15psi it went off again. Is the unit over heating? Or is this normal?
Could anyone tell me if I have to worry about this and what to do to fix it if anything. Thanks
Pressure relief valve
Set to open at 15 psi on steam boilers,it should not be doing what it`s doing under normal operating conditions.
You might have an improperly set or defective pressuretrol or the relief valve itself is defective,you might want to call a pro .0 -
Not normal!!! TURN IT OFF!!!
Be happy that your pressure relief valve is working properly, because something else most assuredly isn't. A residential boiler should never, ever go over a few psi (most fittings, valves, etc., are rated around 3 psi, with a never exceed of 10).
TURN OFF THAT BOILER NOW, with the emergency switch, and get a pro in there, pronto, to find out what's wrong. I do not want to sound alarmist, but if that safety valve happened to stick shut, what you have could launch your whole house into low orbit.Br. Jamie, osb
Steam heat
Thanks, its been off since it did it the second time and I watched it. I will have to call someone Monday, I suppose to get it looked at0 -
You need a Pro!
Jim S and Jamie's advice is right on. You have a serious safety issue. Call a pro to look at it. If it is what i think it is it's a simple fix.
I read this post and was thinking you might want to get Dan's book "We Got Steam Heat!. it's available on this site Here's the link:
http://www.heatinghelp.com/products/Books/5/61/We-Got-Steam-Heat-A-Homeowners-Guide-to-Peaceful-Coexistence
It's written for the homeowner, is humorous, and is easy to understand. After an evening or two of reading you'll know a lot more about your steam system. For most people the knowledge learned from this book has saved them many times its value.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
