switch over from auto-lite pilot to standing pilot - damper question
[Deleted User]
in Gas Heating
Hi,
I have a utica boiler (mgb) that was switched from a auto-lighting pilot to a standing pilot due to reliability issues with the auto-light. I have an automatic damper on the unit with a small exhaust hole. I went down to inspect the work and noticed that some warm air/exhaust was coming out from the front of the hood. I am concerned about CO with this so I shut-off the auto-damper, leaving it open. Has anyone else had a similar issue or could you offer some advice? Do you see a potential CO problem with leaving the auto-damper engaged?
Thanks
Mike
Thanks
Mike
If the boiler had been running recently
it's probably just air drafting thru the sections. But why not have it checked with a digital analyzer to be sure? If whoever did the work doesn't have an analyzer, find someone who does.All Steamed Up, Inc.
Consulting0 -
Do you have a CO detectot?
If not a good idea to get one. It is also a good idea to have a spill switch mounted on the draft hood just in case flue gases spill into the room.
Have a professional come and do a combustion test and install a spill switch (blocked vent switch).0 -
tech said no issue
I have a CO detector.
The tech said there is no issue that it is the same as having a pilot light on the stove.
Thanks for your replies.
-Mike0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
