Roaring sound from boiler
Andy_27
Member Posts: 17
in Gas Heating
<span style="font-size:12pt">I don’t know if its my aging ears or not but my 16 year old Weil-Mclain gas boiler seems to be making more of a roaring combustion sound at ignition for about 15 – 20 seconds. It then settles down to a quite operation. Maybe this is something I’m just noting and is normal operation or could it be the gas valve staring to operate incorrectly. Any opinions ?</span>
<span style="font-size:12pt"> </span>
<span style="font-size:12pt">Thanks</span>
clean it
Just give it a good cleaning and you should be ok. Dust and lint build up on and in the burner tubes and you get some dust and ash build up on the boiler pins as well which can lead to louder starts and a decrease in boiler efficiency. It is a pretty easy job if the boiler was installed in a serviceable area. ;-) So call your local heating contractor and arraign for a boiler cleaning .0 -
In addition
to cleaning have it checked for proper ignition and have a combustion analysis done.0
- 50 Industry Classes
