Weil Mclain or Peerless ?
SteamHeat
SteamHeat Member Posts: 159
150,000 Gas Fired Steam.
Would you use Weil McLain or Peerless and Why?
Thanks in advance.
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,578
    boiler choice
    i would choose the installer first, then use the boiler he is most confident in. make sure the boiler is sized correctly to the radiation total.  also important, is having a stocking distributor not too far away.--nbc
  • SteamHeat
    Weil Mclain or Peerless?
    Thank you. These are very salient points.
