Weil Mclain or Peerless ?
SteamHeat
Member Posts: 159
150,000 Gas Fired Steam.
Would you use Weil McLain or Peerless and Why?
Thanks in advance.
Thanks in advance.
boiler choice
i would choose the installer first, then use the boiler he is most confident in. make sure the boiler is sized correctly to the radiation total. also important, is having a stocking distributor not too far away.--nbc0 -
Weil Mclain or Peerless?
Thank you. These are very salient points.0
- 87K THE MAIN WALL
- 57 Biomass
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 988 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
