Ok to transplant a burner
russiand
Member Posts: 75
in Oil Heating
I have a leaking Burnaham V73 with a Becket AFG firing at 1.05 GPH. I am on a bit of a budget and wan to know f I get a knockdown V8 can I just transplant my existing burner into it. Specs for the V83 show identical firing rate, so even though the burner is not 100% the same (same family though) does anybody see a problem? I know the V8 native burner has a nice noise box around it, but I don't care about the noise.
Burner
Can be set up with the proper combustion equipment. Before you make a decision I would suggest you give Burnham a call. That boiler may be covered or atleast a portion of it's value under warranty. It is handled a couple of ways. They will send a replacement jacket block but the contractor will have to strip your current boiler of the burner, aquastat and the other essentials and put them on the block. They also offer a rebate on warranty boilers. They would rather see you up-grade to the new V8H or MPO. Speak to them prior to doing anything. The V7 series of boilers had a mass leaking problem. Let me guess, it's leaking 2nd section mid.There was an error rendering this rich post.
Good point on combustion test
I found out about V7 fiasco after purchasing the house. This one unfortunately one with a tankless coil,and the leak is between the rear section and the middle one right above the coil. The trouble it is not a crack like the classic failure I think but rather a leak between the sections, I think right where the coil push nipple is around the tankless coil. I drained the boiler and used some JB weld to seal the leak. Seems to be holding temporarily ( or leaking somewhere and steaming off) but obviously not a real fix... Burnham is willing to spring 750 bucks towards a V83 with a tankless (don't want that) or a V83 or Mpo with an Alliance SL indirect. Obviously thats the way to go, but I have to go through a licensed pro to get the rebate. Mpo is obviously the better choise, but means I most likely need a chimney reline, which I am not ready to budget for just yet. Trying to find a cost effective solution here and get through this heating season on a budget.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
