Weil Mclain or Peerless ?
SteamHeat
Member Posts: 159
150,000 Gas Fired Steam.
Would you use Weil McLain or Peerless and Why?
Thanks in advance.
Thanks in advance.
boiler choice
i would choose the installer first, then use the boiler he is most confident in. make sure the boiler is sized correctly to the radiation total. also important, is having a stocking distributor not too far away.--nbc0 -
Weil Mclain or Peerless?
Thank you. These are very salient points.0
