pex question please
ddenny
Member Posts: 75
Is "A" pex really better than B or C pex? how so
thank you
thank you
pex is pex
Any salesperson can sell you the advantage of one pex over any other pex, a,b, c or d. Even between like manufactures the sales people will sell, it's their job.
Bottom line is they all work, they all have a 25 year warranty, they have all been successful.0 -
Pex is Pex
I agree to a point "Pex A" does have advantages of the others though. The fitting system is just as important as the tubing itself. Some of the "b" and "c" guys are beginning to see so problems associated with the crimp style fittng approach where the fitting is not holding up to agressive water as the walls of those ftgs are not as large as the "A" guy.
With the "A" guy the tubing itself along with a ring made of the same material forms the joint vs a forced joint with some type of metal band. It may not be so critical in a plbg application but on a heating application I wouln't be comfortable with a crimp type fitting system. I'm not saying it won't work or fail over time but the "A" guy use to have a crimp type system for a little while and found some long terms problems associated with it so they stopped using that type of system.There was an error rendering this rich post.
Second That
Amen,
Buy the installer, buy the wholesaler, buy the system.0 -
I prefer
pex a. easier to work with bends in a smaller radius. Better for making tighter tubing layouts.There was an error rendering this rich post.
- 167 Indoor-Air Quality
