HELP!
PC
Member Posts: 24
A couple of heating seasons ago I asked for help to look for someone who knew steam in our area and was familiar with old systems. Had a contractor out from a mechanical company who does some large installations but, I'm still searching for someone who KNOWS old steam and can help me get things right. I won't go into the story of what's happened so far to save time... I can fill someone in if they're curious.
I'm in Michigan located 1/2 hour northwest of Ann Arbor... 45 minutes east of Lansing.
It's an old US Radiator retro-fitted with a Budco gas burner one-pipe steam system in an 1850 historical home.
Many thanks in advance for advice
1850 steam
first, do you have a copy of "the lost art of steam heating" to show any contractor you may meet?
maybe someone at the plumbing supply houses listed below, or the union hall, knows of a retired steam pro who could assist?
if i were in your shoes, i would first buy a good low pressure gauge [gaugestore.com 0-3 PSI], and have it installed with a new brass pigtail, all together with whatever pressure control you now have [leaving room for for the inevitable future vaporstat installation]. as many problems arise from over-pressure, you would then be able to see what pressure you have.
why not list the symptoms you experience anyway, and the suggestions here may point even a knucklehead in the right direction. pictures of the boiler and piping are worth a thousand words!--nbc
when i did a search on the peerless boiler website, i found the following:
[u][color=#810081]http://www.peerlessboilers.com/Default.aspx?TabId=171[/color][/u]
Find an Installer or Wholesaler
Use the search below to find a Peerless Installer or Wholesaler near you. If you do not find a Peerless Installer or Wholesaler near you, please [u][color=#0000ff]contact us[/color][/u]. Thank you.Enter your 5-digit zip code:
Zip code must contain 5 digits
Zip code is required Distance in miles (radius): 50 25 20 15 10 5
Results for zip code: 4810426.5 milesHI Cooling & Heating
18536 Plainview
Detroit, MI 48219
Wayne County P: 313-537-8170 313-537-8170
4.6 milesJOHNSTONE SUPPLY #32
LA RIDDLE
119 JACKSON INDUSTRIAL DRIVE
ANN ARBOR, MI 48103
Washtenaw County P: 734-995-3500 734-995-3500
F: 734-995-3501
Contact this Distributor for a Peerless installer in your area.19.3 milesHARRISON PIPING SUPPLY
38777 SCHOOLCRAFT
Livonia, MI 48150
Wayne County P: 313-464-4400 313-464-4400
Contact this Distributor for a Peerless installer in your area.19.5 milesJOHNSTONE SUPPLY #25
DAWN BANNASCH
28451 WICK ROAD
ROMULUS, MI 48174
Wayne County P: 734-947-1111 734-947-1111
F: 734-947-9999
Contact this Distributor for a Peerless installer in your area.28.4 milesJOHNSTONE SUPPLY #22
L.A. RIDDLE
12800 LYNDON STREET
DETROIT, MI 48227
Wayne County P: 313-491-4911 313-491-4911
F: 313-491-3600
Contact this Distributor for a Peerless installer in your area.28.7 milesMETRO HARDWARE & BLDG SUPPLY
DONALD HOULAHAN
4000 TOWN CENTER SUITE 8
SOUTHFIELD, MI 48075
Oakland County P: 248-356-2600 248-356-2600
Contact this Distributor for a Peerless installer in your area.33.8 milesDETROIT SAFETY FURNACE
MIKE SHORKEY
5960 SECOND BLVD
Detroit, MI 48202
Wayne County P: 313-832-2221 313-832-2221
Contact this Distributor for a Peerless installer in your area.35.3 milesJOHNSTONE SUPPLY #336
RICH MEYERS
903 BELDEN RD
Jackson, MI 49203
Jackson County P: 517-998-3600 517-998-3600
F: 517-998-3603
Contact this Distributor for a Peerless installer in your area.35.4 milesWILLIAM NORTH CO. INC.
W. H. NORTH
311 N. WISNER ST.
JACKSON, MI 49202
Jackson County P: 517-289-7529 517-289-7529
Contact this Distributor for a Peerless installer in your area.35.6 milesJOHNSTONE SUPPLY #95
AMBER SHEEHAN
32571 STEPHENSON HIGHWAY
MADISON HEIGHTS, MI 48071
Oakland County P: 248-589-3130 248-589-3130
F: 248-585-2528
Contact this Distributor for a Peerless installer in your area.39.1 milesJOHNSTONE SUPPLY #32
JOHN KAMIN
927 BROWN ROAD, UNIT D
ORION, MI 48359
Oakland County P: 248-391-4543 248-391-4543
F: 248-391-2542
Contact this Distributor for a Peerless installer in your area.43.3 milesJOHNSTONE SUPPLY #30
ERIK OLSON
27450 GROESBECK HWY
ROSEVILLE, MI 48066
Macomb County P: 586-774-8000 586-774-8000
F: 586-774-8002
Contact this Distributor for a Peerless installer in your area.47.2 milesJOHNSTONE SUPPLY #25
JASON EBERLY
1646 HOLLAND ROAD
MAUMEE, OH 43537
Lucas County P: 419-893-1043 419-893-1043
F: 419-893-1026
Contact this Distributor for a Peerless installer in your area.47.2 milesFerguson Heating & Cooling
1435 Holland Rd
Maumee, OH 43537
Lucas County P: 419-482-0733 419-482-0733
49.1 milesMAUMEE PLBG, HTG & INDUSTRIAL
12860 ECKEL JUNCTION RD
Perrysburg, OH 43552
Wood County P: 419-874-7991 419-874-7991
Contact this Distributor for a Peerless installer in your area.Find an installer or wholesaler near you
Enter your 5-digit zip code in the field below. Search
Zip code must contain 5 digitsRebate Programs
Peerless offers many boiler models that may qualify for tax incentives and rebates.Learn MoreParts to Your Door
Peerless Boilers' official replacement parts distributor. Find parts for all of your HVAC needs.Learn MoreAccount Login login Forgot Password Register
Steam Heating in Michigan
Hi-
First of all you might want to put you posts in the "Strictly Steam" section as they are more likely to be seen by steam people who come on this site
. Finding a steam pro in Michigan maybe a bit of a problem. There was someone from Detroit in the "Strictly Steam" section recently who was looking for a steam pro and so far wasn't having much luck. You might want to ask Gerry Gill in Clevland, (look under "Find a Professional" above) as he might know someone in your area. Also you might want to check will hydronic heating suppliers in your area and they maybe able to recommend someone who knows steam heating.
Actually the best approach is to learn about steam heating yourself. It's fairly easy to learn. Do you have Dan's books on steam heating? If you don't, I would strongly suggest that reading them is a very good place to start. I'd read "We Got Steam Heat" first and then read "The Lost Art of Steam Heating" . You can get them as a package "The Steamy Deal" Here's the link:
http://www.heatinghelp.com/products/Super-Deals/14/129/A-Steamy-Deal
They're easy reading, humorous, written for the homeowner, and will tell you all you need to know about residential steam heating systems. Dan explains things very well and includes lots of illustrations and pictures.
I'm a homeowner myself and have an old (1757) house (1 pipe steam) in Maine. Here there are good plumbers and good "burner men" but very few "steam pros" and none close by. I went through several years of different local guys trying to straighten out my steam system with no luck. in frustration I decided to learn about steam myself and luckily found this site and Dan's books. I was able to do most of the fixing myself and for the heavier work got a good plumber who would work under my direction. One of the big benefits of reading the books is that you now have the knowledge to quickly determine whether the person you are talking to actually understands steam and that helps you sort out the incompetent.
Between the book reading and the helpful pros on this board, who will answer any questions you have, you should be able to quickly get your steam system straightened out.
- Rod
Edit: NBC brought up a really good suggestion for finding a steam pro, that rather than the hydronics supplier, try through the boiler manufacturer. I'd still read "The Books" first as I've run across a few of the "recommended" installers (of another boiler manufacturer) and wasn't overly impressed with their knowledge about steam.0 -
Totally agree
with Rod. Your best bet may be to find a really good (probably older, but not at all necessarily) plumber who is willing to learn, and get yourself the complete set of Dan's books (A Steamy Deal) and learn about steam and your system. That's what I did (I'm a building superintendent, caring for a National Register house/museum with a vapour steam system) about 6 years ago, and it has worked out very well indeed. When questions come up, the folks here on the Wall are very very helpful -- particularly if you have done your own homework. Steam is not hard! Most of it is really common sense.
If you can get in touch with Gerry Gill, he's one of the best around -- but I'm afraid Cleveland may be a little far...Br. Jamie, osb
- 50 Industry Classes
