pat
pattrick
Member Posts: 1
hello all im a nube to all this so here goes ,,, im building a wood fired low pressure boiler in an outside building my plan is to heat the water pump it to the house with a grunfro circ pump to a large exchanger at the house so here are some of my questions the circ pump claims to flo up to 17 gpm ,,,is that enough? the underground distance is about 50 feet next question i plan to use 3/4 pex tubing do the colors of tube make a difference is 3/4 enough it will be in conduit and insulated next question where can i purchace some registers to run the hot water thru ih the house (a nice wall mount type) thanks for any help
Hopefully you don't need this yet
Not a DIY Project
Hi Pat -
I'm not quite sure how to reply to your questions other than to try to discourage you from taking on this project. There are some serious safety issues when putting together a boiler system that an amateur is better to leave well alone. You'll put a lot of time and money into something that will end up inefficient and quite possibly dangerous. This isn't a reflection on your abilities as even a very experienced hydronics specialist I doubt would take on this type of project as there are just too many unknowns. The companies who are doing this professionally are running into serious problems. Here's a links that you might be interested in:
[url=http://www.woodheat.org/technology/obmanufacturer.htm]http://www.woodheat.org/technology/obmanufacturer.htm
http://www.woodheat.org/dhw/dhw.htm
If you want to go with wood heating. I'd thoroughly search out a manufacturer with a proven track record. If it were me I'd look at some of the dual fuel units.I don't know what you have available for fuel but you also might want to look at modcons which are far more efficent and problem free than using wood. if you want to learn more about hydronic heating (hot water), there are a lot of good books available on this site in the "Store" at the top of this page.
- Rod0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 392 Solar
- 55 Water Quality
- 46 Industry Classes
