any interest in this expansion tank bracket?
hot_rod
hot_rod Member Posts: 27,242
it has a double check on the expansion tank connection for easy removal and replacement. Pressure gauge with a check valve, and an air vent with a check under it also. Connection ports for the boiler piping and a relief or fill valve.
Plenty stout as long as it is attached to something solid!
  • mjcromp
    mjcromp Member Posts: 57
    Ohhh
    I like it! Is it a solar part or more geared towards Hydronic? Looks like it would work good for both.
  • Jason Quinn
    Jason Quinn Member Posts: 96
    Very nice
    Give us more info
  • Jason Quinn
    More info...
    as in-  is it available and where?
    It's a part
    Caleffi offers for the european market. Designed for hydronics, no reason it could not be a solar component.
    Here are some "adjustments" I've made to make it more suited for the U.S. market.
    I adapted to all NPT threads, a psi gauge, removed the relief and used that port for the fill valve with either side mounting, and an 1/8" air vent with check. Also 1/2" FIP for the expansion tank.
    I'm working to see what the final cost would be in the U.S. version.
