any interest in this expansion tank bracket?
hot_rod
Member Posts: 24,714
it has a double check on the expansion tank connection for easy removal and replacement. Pressure gauge with a check valve, and an air vent with a check under it also. Connection ports for the boiler piping and a relief or fill valve.
Plenty stout as long as it is attached to something solid!
Ohhh
I like it! Is it a solar part or more geared towards Hydronic? Looks like it would work good for both.There was an error rendering this rich post.
Very nice
Give us more info0 -
More info...
as in- is it available and where?0 -
It's a part
Caleffi offers for the european market. Designed for hydronics, no reason it could not be a solar component.
Here are some "adjustments" I've made to make it more suited for the U.S. market.
I adapted to all NPT threads, a psi gauge, removed the relief and used that port for the fill valve with either side mounting, and an 1/8" air vent with check. Also 1/2" FIP for the expansion tank.
I'm working to see what the final cost would be in the U.S. version.Bob "hot rod" Rohr
Living the hydronic dream0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
