Thermostat for Hot Yoga Room
Paul Pollets
Paul Pollets Member Posts: 3,671
Does anyone know of a 2 wire T-stat that will go to 105-110 degrees F ?
 This would be for heating a hot yoga room (820SF), to 105-110 at 24 degree design. The design calls for wall panel radiators mounted at the ceiling and a mod con boiler. I'm trying to convince them to put the rads under the windows, not on top.
