Thermostat for Hot Yoga Room
Paul Pollets
Member Posts: 3,639
Does anyone know of a 2 wire T-stat that will go to 105-110 degrees F ?
This would be for heating a hot yoga room (820SF), to 105-110 at 24 degree design. The design calls for wall panel radiators mounted at the ceiling and a mod con boiler. I'm trying to convince them to put the rads under the windows, not on top.
hot stuff
would a sauna thermostat work, or even a complete sauna setup?--nbc0 -
Do you mean something like this?
http://www.globalspec.com/FeaturedProducts/Detail/Stego/ET_011_DC_24_V_Electronic_Thermostat/27083/0
60C is about 140F.0
- 84.3K THE MAIN WALL
- 2.9K A-C, Heat Pumps & Refrigeration
- 53 Biomass
- 417 Carbon Monoxide Awareness
- 44 Chimneys & Flues
- 1.8K Domestic Hot Water
- 4.8K Gas Heating
- 120 Geothermal
- 156 Indoor-Air Quality
- 3K Oil Heating
- 57 Pipe Deterioration
- 794 Plumbing
- 5.4K Radiant Heating
- 369 Solar
- 14.1K Strictly Steam
- 3.1K Thermostats and Controls
- 53 Water Quality
- 39 Industry Classes
- 80 Job Opportunities
- 22 Recall Announcements
