Pipe dimensions
Al Letellier_21
Member Posts: 400
OK fellow steam guys, I am installing a Weil SGO 7 and need a piece of pipe cut for the header. Installing a drop header and need a nipple cut between the two tees. Local supplies don't carry big stuff and all is ordered in. Can't find my old fitters book with dimensions on a 4" malleable tee. Have to bush the branches to 2 1/2", but I need the take out dimension of that 4" malleable tee. Spacing on the two risers is 22 1/8 " C-C but if you have the dimensions on the tee, I can figure it from there.
Thanks in advance for your help.
4" tee
Al, Face to face across a 4" 150 lb malleable tee is 71/2" in modern books and 7.58"
in some of the older ones.There was an error rendering this rich post.
fitting dimensions
Thanks for the information, Bob. A big help.
AL0 -
Dimensions
Al you can also check out McMaster Carrs website, they give dimensions on the fittings they sell0
- 167 Indoor-Air Quality
