Pipe dimensions
OK fellow steam guys, I am installing a Weil SGO 7 and need a piece of pipe cut for the header. Installing a drop header and need a nipple cut between the two tees. Local supplies don't carry big stuff and all is ordered in. Can't find my old fitters book with dimensions on a 4" malleable tee. Have to bush the branches to 2 1/2", but I need the take out dimension of that 4" malleable tee. Spacing on the two risers is 22 1/8 " C-C but if you have the dimensions on the tee, I can figure it from there.
Thanks in advance for your help.
  • bob_46
    bob_46 Member Posts: 813
    4" tee
    Al, Face to face across a 4" 150 lb malleable tee is 71/2" in modern books and 7.58"
    in some of the older ones.
  • Al Letellier_21
    Al Letellier_21 Member Posts: 400
    fitting dimensions
    Thanks for the information, Bob. A big help.
    AL
  • MikeyB
    MikeyB Member Posts: 696
    Dimensions
    Al you can also check out McMaster Carrs website, they give dimensions on the fittings they sell
