Variable speed compressors for GSHP systems.
Mark Eatherton
Member Posts: 5,875
I have been removed from the industry for a while. Is there anything new and exciting, like Mitsubishi's variable speed compressors coming out onto the market for use with GSHP systems yet?
I had heard rumors that an American manufacturer would be coming out with a 5 ton unit in the near future (last year) with a Mitsu style inverter technology compressor on board.
Anyone?
If it ain't happening yet, I will be forced to make my own 5 stage, 5 ton system using 1 ton compressors. This is for my demonstration project up in yonder hills.
ME
Anyone?
ME
yes
My rep mentioned to me that ClimateMaster has an operational water to water w/variable speed compressor prototype being field tested right now.0 -
WONDERFUL!!
My prayers have been answered by the hydronic gawds.I hope they release it in the near future.Maybe I can talk them into ginuea pigging with me at 8'000 above sea level. :-)Climate Master is who I was thinking of.THAT will certainly reduce the size of the bufferin' tank, if not eliminate it completely.I'm glad the industry is finally listening to its customers.ME0 -
pumping
then all we need to do is show them that pumps come in fractional horsepower and they are quite adequate on the load side of most units, if they would lower the pressure drop and flow requirements a little bit...
nothing like pairing up an alpha with whatever monstrosity they require on the geo load side circuit.Rob Brown
EVERYTHING in modulation....
There is absolutely no reason in my hydronic mind that why all three sides of a refrigerant system can't be in modulation, and in harmony for that matter.
The load is a variable, so the source (loop field), load (distribution side) and transfer agent (compressor, exchangers etc) should ALSO be variables.
On the loop, speed maintained by delta T (usually a tight one).
On the load side, flow based on either calculated head, or temperature differential, and the compressor based on deviation from a dictated set point temperature using a zero to 10 volt DC signal. Every thing else will fall in place...
But bear in mind, I am NOT an expert in refrigerant operations... Please feel free to correct me where I am wrong.
ME0 -
Econar Low flow/pressure drop
Econar makes a nice unit and they seem to have a lower flow and pressure drop requirement. Not sure if its enough to get you where you want though.0
- 123 Chimneys & Flues
