Hot Water Hotter at Bath Faucet
RobLC
Member Posts: 93
The water coming out of the hot water faucet in the bathtub is hotter than the water coming out of the hot water faucet in the basin.
If you go into the basement, it appears (appears, but might not be so) both faucets are being fed by the same hot water pipe from the hot water heater.
Has anyone ever come across this?
Thank you.
Thank you.
Are they single handle faucets
I have seen some cartridges leak through0 -
Got DHW recirculation return?
Have seen the check valve fail and allow cooler water to run backwards through the system and mix at the point of use...
METhere was an error rendering this rich post.
Thanks, to Tony S and Mark Eatherton...
Thanks for taking the time to answer my question.
I'll see what I can find. I'm not sure I'll be able to find the check valve.
Thanks again for the replies.
RobLC0 -
hot water
are the faucets single lever, Some single lever cartridges fit basin faucets and shower valves and have limit stops for scald protection. if so it needs adjusting.0 -
Volume
There is a good chance that the lav faucet has a flow resticter in the aerator. The bathtub faucet does not require a flow restricter. You are getting lots more water through the tub faucet.
Rich Kontny0 -
Thank you, Kevinnj and Rich Konyny...
The faucet is the classic Delta - - one valve for cold and one valve for hot.
Yes, the basin faucet does have an aerator.
I will look into these things.
Thank you for taking the time to answer my question.
RobLC0 -
Apologies, Rich Kontny...
Must be a little tired.
Thanks, again.0 -
Try turning...
... the cold supply off at the sink. See if the hot water gets hotter. If so, you know there is some cross connection in the sink valve. Another test for cross connection is to shut off the cold supply to the heater and open a hot tap. If it doesn't stop running pretty soon, it is either because cold is entering the system somewhere or the shutoff valve doesn't really shut off.
Yours, Larry0 -
Thank you, Larry...
Yes, Ok, will give a try.
Thank you for your help on this one.
RobLC0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
