Wireless T stats
Ronh
Ronh Member Posts: 1
Anyone having good luck with wireless thermostats?
  • Al Letellier_21
    Al Letellier_21 Member Posts: 400
    wireless t stats
    have used the Honeywell set-up on half a dozen jobs and no issues other than dead batteries. Some attention needs to be put into reading the instructions for proper wiring,  like the need for an isolation relay between the receiver and you zone controller as 24 volts is present in both controls. Other than that, they are great and save a lot of work running wires in old houses.
