Wireless T stats
Ronh
Member Posts: 1
Anyone having good luck with wireless thermostats?
wireless t stats
have used the Honeywell set-up on half a dozen jobs and no issues other than dead batteries. Some attention needs to be put into reading the instructions for proper wiring, like the need for an isolation relay between the receiver and you zone controller as 24 volts is present in both controls. Other than that, they are great and save a lot of work running wires in old houses.0
- 114 Geothermal
