New Home / Old Boiler-Burner
NShak
Member Posts: 38
in Oil Heating
A friend bought a "new home" that has a Burnham RS-111 boiler-burner.
We've learned that it has a tankless coil heating element for the
house's hot water. We're not clear on how the steam heat works-
radiators throughout the house are 2-pipe. I'm assuming this is steam;
could it actually be hot water heated radiators? It also has an
expansion tank which we're not clear how that works either. Can
anybody help us figure out how this kind of system works? Thanks in
advance.
advance.
is not steam/ / is gravity or forced hot water
expansion tank is place for your heating water to expand into...as all things expand when heated../// the tankless coil heats domestic water as needed as used.... it should have a flow restrictor & good quality anti-scald rated mixing/tempering valve in the piping.0 -
circulator??
Does your boiler have a circulator if yes then its hot water.It seems you never had oil heat(or ur friend) may be a good idea to have a tech from your local oil co. come over for a tune-up and ask lots of questions.0
