Looking for a better water heater than tankless coil
kspring
Member Posts: 1
I purchased a home in the NYC suburbs with a tankless coil water heater system. This works off of my oil boiler which otherwise heats my house with a radiant system. From what I have read this tankless coil is not a very efficient system. My house has three bathrooms, a dishwasher, and a washing machine. I have a gas line readily available next to my boiler. I have been looking into getting a more efficient system for heating my water. I go through about 400 gallons of oil in the summer, when my boiler is used only to heat my water. I have had a few water heating techs come by and give their suggestions. I have been told various things. One idea was to add a tank onto my current system ( this compromised of adding another zone to my boiler and was the most expensive option). Another was to install a tankless gas water heater (about half as expensive as the first option). The third was to install a gas water heater tank (the cheapest option). What system should I go with?
Navien Tankless
operate at 98% efficientcy and only run when you turn on the water. 15 year warranty it is the epitome of gas water heating. The other option would be one of the new heat pump water heaters or the add on heat pump to an electric water heater.0 -
The
cost of an indirect water heater is usually less than a tankless instantaneous. I'd go with either of those.If the boiler is getting long in the tooth,how about a mod/con w indirect? Large tax credits and rebates available0 -
water heater options
be carefull with tankless if you have 3 bathrooms it may not be enough.
check the GPM @ A 90 DEGREE Tempeture rise. calculating your demand will help you decide0
- 167 Indoor-Air Quality
