Safety Valve Pressure Settings
PCBOILERMAN
Member Posts: 11
We have two HP fire tube boilers at a MAWP of 150 psig. If additional safety valves are used, what does it mean when the complete range of pressure settings of all the safety valves shall not exceed 10% of the highest pressure to which any valve is set? From NYC boiler code Part 14.
Just A Guess,,,
but I would think MAWP + or - 10% of valve setting is all that is allowed.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
