Dielectric coupling for higher temp
I have steel pipe and a brass valve in a 240 deg medium temp system. The highest rated dielectric coupling I can find is 230 deg. Any one no of a dielectric coupling with a higher temp rating? Can an arguement be made that I don't need it?
  • Peter Turk
    Peter Turk Member Posts: 10
    You don't need dielectic couplings for bronze to black steel
    The highest temp rating I have seen for dielectric is also 230 F.
    But pending on the alloy of the valve, you don't need dielectric protection. Brass/bronze is an alloy and does not react at the same rate as pure copper. Typically you do not need dielectric protection for a bronze alloy on black steel like you would need for copper to black steel.
  • If it's
    a closed system, you don't need dielectric protection.  Without oxygen in the water, there's no place for electrons to go.
