Dielectric coupling for higher temp
I have steel pipe and a brass valve in a 240 deg medium temp system. The highest rated dielectric coupling I can find is 230 deg. Any one no of a dielectric coupling with a higher temp rating? Can an arguement be made that I don't need it?
You don't need dielectic couplings for bronze to black steel
The highest temp rating I have seen for dielectric is also 230 F.
But pending on the alloy of the valve, you don't need dielectric protection. Brass/bronze is an alloy and does not react at the same rate as pure copper. Typically you do not need dielectric protection for a bronze alloy on black steel like you would need for copper to black steel.0 -
If it's
a closed system, you don't need dielectric protection. Without oxygen in the water, there's no place for electrons to go.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
