Dual Mod/Con Install Pics
Devan
Devan Member Posts: 135
Thought I try out adding pix to the new site.
Here is a job we are working on now.
Two Buderus GB142's, LLH, Grundfos Alpha pumps. Manifolds to hot water baseboard heat through out, 4 towel warmers in baths, and runtal panel rad. Total 8 zones, 7500 sq.ft second home looking west to the Catskills.
  • Devan
    Trying again.
    Could not add another image using the add another image button. Safari Java script error?
  • Devan
    One last time
    Here is the boiler wall.
  • Devan
    Whew!
    Also security check must be on a timer. Trying to upload an image to the wall, ending up typing in a new code three times before sucess.
  • PaulR
    PaulR Member Posts: 25
    A safe bet
    It is a safe bet that this job is a contender if not a sure thing for some System Showcase accolades.
    Beautiful work Devan.  Is that grey melamine?  Very well thought out and I love the piping as it dissapears into the wall.  Your concealed wiring is top shelf.
    I think I will have to go "Tonya Harding" on you before the System Showcase Awards if I'm to have a chance.  :)
    Best to you,
    Paul
  • Rich Davis_2
    Rich Davis_2 Member Posts: 121
    Wire on Pumps?
    Are those electric cords hanging on the iso-valves on the system pumps?  If so what are they for?
    hot_rod Member Posts: 25,069
    nice layout
    I like the way you offset with the 45's nice work. Great components also.
    Yeah, I'm torn on the corded versions of the Grundfos. I like that you don't need to get inside, the pump to wire it, but it limits you to that wire??
    hr
  • Devan
    Thanks Paul
    was not really thinking about system showcase awards for this one, but I may have a few other jobs in contention ; )
  • Devan
    Thanks
    Yep, the Grundfos Alpha has a quick connect cord connection.
    Downside, you have to use it, I will probably finish up the wiring soon, I just
    did not want to cut those cords yet until I made sure they worked ok.
    It is pretty cool though when you close off zone valve , and you see the wattage drop as displayed on the pump.
  • CC.Rob
    CC.Rob Member Posts: 130
    edited August 2009
    alpha wiring
    Forgive my ignorance, but how does one wire these Alphas to something like a Taco SR?
    Thanks.
    p.s. gorgeous install!
  • gerry gill
    gerry gill Member Posts: 3,078
    edited August 2009
    Darn nice looking job Devan!
    and yup, posting here is now a we bit of a pain. I typed a respone to a thread yesterday and the security garbage dropped me out and i lost my typing. I said the heck with it since i type with the one finger search and destroy method..but anyways, i digress, you do some really nice pipe work!
    gwgillplumbingandheating.com
  • Devan
    Thank Rob
    Is that you NRT.Rob?
    Just cut the ends off the leads, then wire as normal into a taco,grundfos,argo or tekmar relay panel.
  • CC.Rob
    no...
    Not NRT.Rob. CC.Rob. Gotta update the profile I guess. Thanks.
  • Supply House Rick
    Supply House Rick Member Posts: 1,399
    Beautiful work my old friend
    You are still a master craftsman. It's always a pleasure seeing someone's work that they take pride in!
    Rick
  • Devan
    Thanks Rick
    Thanks for the kind words Rick. Hope you're doing well.
    Peace,
    Devan
