Can I install thermostatic radiator valves in a gravity system?
goes to 1 1/4" TRV.
However, you may not need to size the valve to the pipe diameter, but the load on the radiator.
bb
  • thermostatic radiator valves
    Can I install these in the supply lines to my radiators if I have a gravity system with an expansion tank...(open system) or do these thermostats require a closed systme with circulation pump?
    Thank you..
    -confused in Quincy MA
  • Why not?
    The only problem you may have is finding a TRV larger than 1".
  • Yes you can
    Done it many times. Makes a real nice system.
