hot water boilers
Our 23 yr old Penzotti boiler needs to be replaced. It is under a full service (replacement) contract and the fuel company wants to replace it with a Trio PurePro. Is this a good boiler or are they just trying to get out as inexpensively as they can? We live in Maine (cold winters)and have an 80 year old home with 4 heating zones, if that is relevant. Many thanks.
  • Big Ed_4
    Big Ed_4 Posts: 3,585
    Mario
    Not sure about the me Trio. Sorry .. Can I ask what went wrong with your Penzotti ... I use to install Penzittis before they went away ...I did not expect them to go bad ....
  • New boiler
    Jane, I am in Maine (Portland Area) and I can't say that I have ever heard of this unit. If you would like, contact me directly via e-mail and I will be glad to look into it for you.
  • Jane it is a nice boiler. well made and efficient. They are a reasonable price but not a cheap made boiler. They are sold through F.W. Webb wholesalers. You can do a search as before I started installing them I asked on the wall too.
    cell # 413-841-6726
  • kpc_74
    kpc_74 Posts: 14
    really...
    first I have heard of a Pensotti going down. What happened?Trio is fine. The installer is just as important as the boiler... get references.
  • Nice little boiler..................
    Al and Jane,
    It's a re badged Biasi/Solaia three pass boiler. This one Trio is again re badged for Webb, I have installed a few with great results. John@Reliable PS Al hows retirement lol
  • jane_4
    jane_4 Posts: 2
    thank you for all your responses. As far as the Pensotti goes, apparently there was a failure of one of the welded sections within the furnace resulting in a leakage of combustible gas.This caused corrosion of the burner housing - the entire side just rusted through. The oil burner tech told us that this is the fourth Pensotti he's seen with the same problem.
  • PatsFan78
    PatsFan78 Posts: 2
    Pensotti boilers are still available and in the market. They are based out of Maine. There current line is called the DK2 series and it is an efficient low-mass, triple-pass, Energy Star Rated, European style boiler. Very reliable.
    Proper maintenance is the most important thing when it comes to your heating system. Ask around when deciding a service company, referrals are the best form of research.
    good luck,
    Mike
    www.hitechheat.com
  • Bill Julian
    Bill Julian Posts: 164
    No Hot water flow
    Just installed another zone ^ existing this makes 7 on a hot water boiler for a basement zone. I'm getting no circulation for some reason. The hot water will circulate when I use the fast fill but on its own it will not.
    I do have 2 U shaped turns (ceiling to floor) which could be causing the problem. The line seems to be purged of air wondering if a circulator on this basement zone will do the trick.
