hot water boilers
jane_4
Our 23 yr old Penzotti boiler needs to be replaced. It is under a full service (replacement) contract and the fuel company wants to replace it with a Trio PurePro. Is this a good boiler or are they just trying to get out as inexpensively as they can? We live in Maine (cold winters)and have an 80 year old home with 4 heating zones, if that is relevant. Many thanks.
Mario
Not sure about the me Trio. Sorry .. Can I ask what went wrong with your Penzotti ... I use to install Penzittis before they went away ...I did not expect them to go bad ....There was an error rendering this rich post.
New boiler
Jane, I am in Maine (Portland Area) and I can't say that I have ever heard of this unit. If you would like, contact me directly via e-mail and I will be glad to look into it for you.0 -
Jane it is a nice boiler. well made and efficient. They are a reasonable price but not a cheap made boiler. They are sold through F.W. Webb wholesalers. You can do a search as before I started installing them I asked on the wall too.Cost is what you spend , value is what you get.
cell # 413-841-6726
really...
first I have heard of a Pensotti going down. What happened?Trio is fine. The installer is just as important as the boiler... get references.0 -
Nice little boiler..................
Al and Jane,
It's a re badged Biasi/Solaia three pass boiler. This one Trio is again re badged for Webb, I have installed a few with great results. John@Reliable PS Al hows retirement lol0 -
thank you for all your responses. As far as the Pensotti goes, apparently there was a failure of one of the welded sections within the furnace resulting in a leakage of combustible gas.This caused corrosion of the burner housing - the entire side just rusted through. The oil burner tech told us that this is the fourth Pensotti he's seen with the same problem.0 -
Pensotti boilers are still available and in the market. They are based out of Maine. There current line is called the DK2 series and it is an efficient low-mass, triple-pass, Energy Star Rated, European style boiler. Very reliable.
Proper maintenance is the most important thing when it comes to your heating system. Ask around when deciding a service company, referrals are the best form of research.
good luck,
Mike
www.hitechheat.com0 -
No Hot water flow
Just installed another zone ^ existing this makes 7 on a hot water boiler for a basement zone. I'm getting no circulation for some reason. The hot water will circulate when I use the fast fill but on its own it will not.
I do have 2 U shaped turns (ceiling to floor) which could be causing the problem. The line seems to be purged of air wondering if a circulator on this basement zone will do the trick.0
- 133 Chimneys & Flues
