Bearings
Techman
Member Posts: 2,143
How can you tell if a motor has sleeve bearings or ball bearings?
take it apart - or read the nameplate --it will be listed as to what type of bearings -why ?0 -
bearings
I don't recall seeing the type of bearings on the motor name plate.And taking apart a good motor doesn't seem logical. I am using an ICM head pressure controller which varies the motor speed.There are two differant settings,one for sleeve bearings and the other for ball bearings.0 -
call the manufacturer --or check that rating plate again0 -
bearings
O.K. Thanks.0 -
quick quess
techman it seems to me most residental units are sleve bearing and as i see it most ommerial are also unless the unit came with a fan cyling /head pressure controller then usually there bearing ,bearing motors are usually more money so you an usually exept to see sleve bearing motors hope that helped peace and good luck clammyR.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Specializing in steam and hydronic heating0
- 50 Industry Classes
