Need Straight Radiator Valve
an old wrench puller
Member Posts: 73
If it was me, in my house I would block up the radiators so that I could use an angle valve. I prefer angle valves in these applications. This also helps getting the pitch right. Are you sure you need 1 1/2 valves? check the ratings on the radiators and the valves. i dont like seeing radiators with out valves, but it would work.
Warning: DIY guy question.
Now that heating season is over, I have the opportunity to add radiators to a couple of unheated upstairs rooms. What I plan to do is to move a couple of downstairs radiators (single pipe steam) over a little, replace the angle supply valve with a tee so I can continue the risers upstairs, and to hook the downstairs radiators back up with straight shut-offs (1 1/2"). I do have access to a pipe threader, etc.
1) Does this make sense? (I have plenty of boiler capacity.)
2) What kind of straight valves should I get, and were can I buy them online? Or . . . do I just use full ported ball valves? (rather industrial)
Thanks in advance!0 -
Wow
A $220 high pressure valve seems a bit expensive. Is there anything else?0 -
CONNECT IT WITHOUT A VALVE.0 -
what he said
al, just hook it up without a valve, 1 pipe you shouln't be throttling it anyway. i would be more concerned about checking the sizes of riser and horz. run from main to the riser to see if it can handle intended load. rob0 -
I would be very careful here Al,
did you edit your original post?,, it sounds to me like you want to extend what is now a single rad riser upstairs, presumably to pick-up other rads too, but still leaving the original downstairs rad(except moved-over)intact?
You may be asking an awful-lot of a riser-size that was intended to be used for a single one-pipe rad. ;-)
Dave0 -
1 1/2 \" = mucho btu lol
if the riser is 1 1/2 " he should be o.k., Dave. the branch radiator might should be 1 1/4 " though.0 -
I agree bob, old friend,
but he says he wants to add a "few" upstairs,, that can be a pretty broad statement, given we don`t know whats on the system below.
Don`t you agree?
Dave0 -
we can only go so far for do-it-yourselfers
i agree 100 % ,Dave. but i am not going to the office & breaking out the rating charts because we ain't making a dime on this job !! brad white would draw him up a free set of plans. that's another story.0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 990 Plumbing
- 389 Solar
