OT-recircs
Bob Bona_4
UP 10-16's work nicely, Jack. Caveat: at times, there will be a tiny period of lukewarm water at the cold tap-nature of the beast.
  • jackchips_2
    jackchips_2 Member Posts: 1,337
    Does anyone
    have any information or have used and can give a recommendation on the recirc pumps that go under a lav or kitchen sink and use the cold water for the return?
    My wife's lav is over 60 feet away and with the continued increase in water and sewer fees it's time to addess it.
    Thanks in advance,
    Jack
  • JK_3
    JK_3 Member Posts: 240
    Taco D'mand
    If the increaseed sewer and water costs are the issue and not the wait time the Taco D'mand may be the answer.Here is the link:
    http://www.taco-hvac.com/news.html?News=106
    Hope this helps
  • jackchips_2
    TK
    It is also the time. I have looked at the taco unit on line but I'm looking for actual experience in how these or other units work. I have a concern about running the hot back through the cold line and about the method of turning it on and off.
    Have you used it?
    Thanks,
    Jack
  • Joe Mattiello
    Joe Mattiello Member Posts: 748
    Taco D'mand system
    I attached some literature on the Taco D'mand pump. Great tool for an existing system retrofit, when you do not have the luxury of a dedicated return line.
    Joe Mattiello
    Taco Comfort Solutions
  • Roland_18
    Roland_18 Member Posts: 147
    Recirc.
    How does one determine which pump to use? There is a coice of 006, 008, or 0011.
  • Chris S
    Chris S Member Posts: 176
    recirc
    I've used Laing on several jobs under the sink, they work well.
    Chris
  • jackchips_2
    Thanks
    for the responses.
    Jack
  • Kevin Koenig_4
    Kevin Koenig_4 Member Posts: 36
    Here is a link to Laings under the counter recirc utilizing ECM mhttp://www.lainginc.com/pages/autocirc.htmotor technology.
