Updating Steam Boiler to a New Riello?
Jean-David Beyer
My old Beckett burner is showing its age. Rather than upgrading the pump, igniter, etc. I was advised by my oil supplier to install a new Riello burner. My question, will a more efficient burner reduce the life of my old steamer, which is working just fine. In any case, the burner needs replacing. Comments and suggestions appreciated. Thanks to all.
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,578
    new burner
    would there be an option of having a "HI-LO-HI" staged firing [75/100%] in the new burner? that could save some money, and might be easier on the old boiler.--nbc
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,584
    A new burner
    won't have any impact on the potential life of the boiler. I'd consider a Beckett NX as well as a Riello.The NX is very quiet and has integral post purge
  • Jon_21
    Jon_21 Member Posts: 2
    Rielllo
    Riello is the best burner on the market. Install a Riello and your service problems will go away, and you'll save $$$ on fuel oil...
  • billtwocase
    billtwocase Member Posts: 2,384
    That being said
    Any burner will only perform as good as the install or the techs servicing it. Riello is a great burner if installed and set up properly. The boiler will not last longer by replacing the burner, infact what make/model/year of steamer do you have? Could be throwing good money after bad? peace
