Roth heating pannels
Sol Hydronics
I would like to see what people think about installing this product, the panels for radiant heat under manufactured hard woods. This will be my first job with this product since there seams to be a shortage of thermo board on the west coast right now. Thanks Mike
I have used Roth. A very good product. Am going to use it in my home this fall.0 -
roth panels
I have found their panels to perform well. I've only used the thinner product that uses 3/8" tube.0 -
I have used it on two Pergo jobs
Performed well.
Rob0 -
Pergo and roth pannels
Thanks to everyone for your thoughts. Using Pergo as a finish did you have to install a sheet of , like plywood over the roth panel? Thanks , Mike0 -
nice product, perfect for the floating floor application. I used it with hardwood and had to rip the panels in half and instal nailers, this was a lot of work.
The product does not hold up well to construction traffic, especially if the plumbers resent you for getting the radiant work. The denting and lifted edges had no effect on this nailed job, but might have been problems for a floating floor.0 -
Nope
They recommend foam or whatever your laminate dealer recommends over the system. Go to the Roth USA website and the install manual is online. A friend of mine used in an older basement ane thinks it's great.0
- 133 Chimneys & Flues
