Water valve question - never saw this
Tony Shupenko
Looked at a home yesterday (modular) with the oddest shut-off valve on the toilets (can hook up a hose). The valve had "Arko" printed with a "C" above the Arko. Research found a company in India (another one in Poland) with this name that makes valves.
At any rate, why would this valve be installed - I am at a loss.
That's a new one on me....
....but maybe the valves were installed to facilitate "winterizing" the houses????? Just a guess!0 -
bidet
It was probably some type of home made bidet faucet.0 -
In a sense, I am glad you are just as confused (thought I was off my hinges). Maybe this facilitated washdown of the bathroom (heck with scrubbing bubbles!), though there were no floor drains
Home was only about 11 years old.0 -
Have seen similar
rig-ups for bidet usage,, not very sanitary & I would think a little nippy on the jewels!
Dave0 -
Salts
The owner takes salts. Summer-salts. He has to hose the place down every time he uses it.There was an error rendering this rich post.
looks like
the two supply lines were too short, and that mess was the first thing his hands rested upon. Sure hope it is removed, or capped off. peace0 -
valve?
Going waaay out on a limb here, but what about feeding hot water through it and tempering the water so the tank doesn't sweat. Or, what if they had a well and only used it for the toilet(s) because the water wasn't potable.0 -
could be
I had installed her a customer one time a bathtub accessory chair for handicapped persons that raised up using water pressure. It was connected by a hose from the valve to that chair and when the valve was opened the chair raised up to assist the person getting in and out of the bathtub. I don't recall the markings on the valve but it was a similar design with a large handle for easy operation.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"There was an error rendering this rich post.
- 133 Chimneys & Flues
