New boiler fill, how long to boil to clear oxygen?
nicholas bonham-carter
Member Posts: 8,578
one person's advice was to bring the water temperature up to 190 deg and leave it; but in your case you will probably want to skim the boiler, and that should be more than enough heating to drive out the oxygen.--nbc
I just had a Smith Model 19-6 re-piped, so it's been drained and refilled. Since heating season is pretty much over, how long should I fire the boiler to clear out the oxygen that is in the water to reduce the corrosion from the new water.
Thanks,
SteveSteve from Denver, CO0 -
Nick's right --
bring it up to a good full boil and the oxygen in the water will be pretty well gone.Br. Jamie, osb
Thanks!Steve from Denver, CO0 -
the real question is
Why was the boiler repiped? Do you have before and after pictures?0
