Vent damper recall
Robert O'Brien
Member Posts: 3,584
http://fieldcontrols.cmail5.com/T/ViewEmail/y/61FD5DF80BB5D55C/768244773BDB73936A4D01E12DB8921D
Thanks Bob
They have been workin on that recall for awhile. And to think they are pushing their new stack damper for oil. peace0 -
Bill
This would make more likely to do business with them.They are admitting a problem,correcting it and offering compensation.0 -
Thanks, Bob
I just installed a replacement vent damper on an old Hydrotherm. It closed on a call for heat and allowed the boiler to fire.
But this recall looks like it's for vent dampers supplied as original equipment. Hmmmmmm.0 -
What`s wrong
with a V/D for oil?
On approved equipment & proper set-up I only see this as a plus.
Dave0 -
Alan (CaliforniaRadiant) Forbes
Was this oil or NG?
Would a spill switch not have helped?
I thought that was code?
Dave0 -
If the product works
I'm all for it. We've been down this road late 70's, early 80's with Flair. Most did not work, and caused many a call back. Field is a pretty good company to deal with on warranty items. They will be out there on units, and time will tell. Wiring is crucial, as in all motorized draft or damper system. Spillage and proven switches have to be in play. Like i said, Every little bit of technology helps us all, just hope it proves to be reliable, for we the middle men take the flack as usual. peace0 -
This was
NG. Sure, the spill switch would have shut off the boiler, but I'm still stuck with a faulty vent damper.0
- 167 Indoor-Air Quality
